Hi Michael. Are you sure you have the right kit for the Weber 28/36 DMA,DLE carburettor ?. When I bought mine about 10 yaers ago from a place in Thornbury, Melbourne called Thornbury Carburettor Services,there were two paper gaskets( For different types of 28/36). a needle and seat,of the same type and dimension as the original,and a small paper gasket,rectangular in shape,but no rubber O rings. I hope you have good luck re fitting the 4 nuts that secure the carb on the manifold,the rear nuts close to the cylinder head,are a real pain,because there is no room to use a socket/ring spanner or open end spanner. Cheers Joe
Thanks Joe,
Those rear nuts are a real pain aren't they! Then again it is a Citroen.
Yeah, I think the rubber bits were a ring in. The rest of the parts are good though and the needle valve is clearly an improved design (it has a spring loaded ball that makes contact with the top of the float) and yes, it had the two top gaskets to cover both models. Strangely I bought it on Ebay from a vendor in Holland for around $40 delivered but on arrival the packaging says "Packed in Australia".
http://www.ebay.com.au/itm/310355530736?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Anyway, the car is running well now and hopefully it has improved the economy and reliability. Not so likely to burst into flames either with a proper screwed in fuel fitting!
