Back on the road and ready for a drive tomorrow. But it's for work, visiting clients and with safe distancing adhered too.
Really John? Mrs. JohnW allowed this? I'm surprised and I hope not on that lovely dining table!I'll advance you cylinder head work in the living room.
Hi Jensen, actually I have some new ones for a rainy day in among my stash of old ones. Thanks anyway sir.Shoji do you need an aus spec R/H taillight? I see you have one of each installed! I’m sure I have a spare I can send you post lockdown.
We were in our early 20s in a rented flat! Worse, the carpet was flecked and I lost a valve collet. It turned up in the end.....Really John? Mrs. JohnW allowed this? I'm surprised and I hope not on that lovely dining table!
Wasn't that long ago then JohnWe were in our early 20s in a rented flat! Worse, the carpet was flecked and I lost a valve collet. It turned up in the end.....
Seems like yesterday..... ROFLWasn't that long ago then John
Thanks Nauli, appreciate it. I will check that once it's all back together. All the pedals are out for a refresh. they were cosmetically affected by the leaking booster that was sortedSo John....how have you measured the reach?
The basic rule is to first set up the seat fore/aft distance so that when you have the clutch fully depressed, you have a bend in your knee. Once that's done adjust the seat back so that when you're sitting back comfortably, stretch your arms out over the top of the steering wheel and your wrists should rest comfortably on the top of the wheel rim.
Yep both Australia and I think California had a push on rubber ( plastic ) cover They just fit over the protrusions. I think they look better with the protection.I notice your instrument binnacle is for the Euro spec. ASFIK the Aussie ones had the more closed in bulky hood over the nacelle. Mine certainly did (built to Aussie specs in France -delivery, London).
I think it was an Aus design rules spec suggesting perhaps you could be impaled on the protrusions!
Thanks Ray. Angru is having a look into his endless stash. Our feed from VicJohn,
The chrome trim for pedals can be from R20 and top range R18. I have for my TX off of a R20.
Ray
Very flash John. VERY. Rumour has it that a certain camshaft is in Perth too. I might be your way next week on R25 business. Personally I'd leave it black but you might want to see the teeth?With the camshaft trigger wheel not working with the NoDiz I decided to change the 16 timing cover to the 17TL cover so I can use the pulley for a 36-1 trigger wheel. Tim (21571) was most obliging to draw up on CAD a wheel suited to the pulley and the cover . Pulley is 100mm and the wheel 130mm. Had the wheel(s) laser cut and the pulley's holes drilled by professionals. I had extra wheels cut while at it. And I found an oulet for 7mm socket cap bolts.
Now, what colour should I do the wheel?
View attachment 127736View attachment 127737View attachment 127738
