Try the commodore ones?your rear springs have to many coils
I'll drive down again sometime soon. We will meet up sometime. I like to stay at the old pub's down south as I like the old woodwork and staircases with all the history. Their a bit of old dives but good for a short stay. Stay safe!Yes, I have seen your car at Ray's workshop sometime last year and drooled over your engine....and you were well and truly noticed in Bridgetown by quite a few local car people...
Slave cylinder leaks. Anyone know the correct part number for these or brand used in 1973 for a TL? I'm up in Perth tomorrow and taking one to Perth Brakes. Hopefully they have stock
Thanks COL. I did a hone on these probably two years back. I think they have weeped since then. But I didn't change the sealsNot sure what brand they are, but if you dismantle the wheel cylinders and look inside the rubbers you will see parts numbers.
Also what is the bore like on the inside of the cylinder? If the cylinder is not to bad you could probably get away with a hone.
The other option is to buy complete replacement slave cylinders.
New complete units I would prefer
I got new seals Col. Will go to Ray's and ask him to hone themI think the rear brakes are the same as found on the Renault R12 wagons which are 9" diameter.
Aha. Renault Dauphine diameter.I think the rear brakes are the same as found on the Renault R12 wagons which are 9" diameter.
Well they look right John. Won't know until later.If Perth Brake didn't manage to supply the correct size seals (my experience) you cannot go past Power Brakes in Adelaide. They actually know what they are doing.
The slave cylinders should hone up ok as long as they are not pitted to badly.I got new seals Col. Will go to Ray's and ask him to hone them
He did hone them with his flash tool. A steel rod with a groove with a bit of sandpaper on the end of a drill. Very technicalThe slave cylinders should hone up ok as long as they are not pitted to badly.
Home prawn pizza is even better...flowers will fix it.
