I can see the browser is throwing 403 loading images.. it must be a config error, as R8RX says they appear when you open in a new tab directly.I've noticed the same thing John. When browsing threads here on AF, some photos don't show but just the name. Refresh and sometimes they show????
They also show just as text, not even a link.I can see the browser is throwing 403 loading images.. it must be a config error, as R8RX says they appear when you open in a new tab directly.
JohnW, I still see the 404's when replying..
I'll raise this with Gerry / Admins.
Thanks Angru. It's fine, I have been assured that the original springs will be ok by some learned people on here. I'm thinking I might use thatThat looks grouse! I have a rear beam that’s been sandblasted and primed... have all the parts to re-assemble... one day! It better come up as good as that!
You’ve found springs? I realize I didn’t get back to you about any.
There is no metal just rustPowder coating is a double edged sword. If not blasted correctly you can still have rust active in the metal and the powder coat layer won't crack and open until all metal underneath is gone. Powder coating also scratches rather easily. I prefer something like the POR15 treatment that reacts with rust to neutralise it.
Very nice John. Very nice.
That wasn't a bit of heat-bluing on the inner bearing area of the stub axle was it? I presume not.
There's always a bit of ongoing debate about the pros and cons of powder coating. I'm going to have to research POR 15 now too!
