Holy shit, internal combustion sure does make me feel things in NSFW places… I do like electric and I like the way they drive and sound. But feck me, when ICE is on song, it makes some fecking amazing music!!!!!
Honda were rocking it 60 years ago too.Holy shit, internal combustion sure does make me feel things in NSFW places… I do like electric and I like the way they drive and sound. But feck me, when ICE is on song, it makes some fecking amazing music!!!!!
Maybe because a 'mild hybrid' can't actually turn the wheels on electric power???I looked up the regos for a few other mild hybrid Range Rovers that were for sale in the UK on the DVLA website. They are all listed as "DIESEL".
That's not the point, it still has a fairly large lithium battery which cannot be discounted as a potential ignition source.Maybe because a 'mild hybrid' can't actually turn the wheels on electric power???
The recently releaased upgrade to the Toyota Hilux has some mild hybrids - and Toyota has given them some other silly name because all the battery does is power some of the electirical equipment in the car.
From the Car Expert article you quote -MHEV will have a small traction battery and an electric motor capable of moving the car.
Unlike most 48V ‘mild’ hybrids, the C5 Aircross offers electric drive, with the French brand claiming some 50 per cent of city-based journeys in EV mode.
Really - it seems they are far more likely to burst into flames than EVs.It's not like E-bikes are known for bursting into flames though I suppose.
Is the Range Rover you quote above a hybrid or a mild hybrid (you've given it two different descriptions in two lines)? Toyota and many other manufacturers manufacture hybrids that can do the same thing as the example and the badging on them says hybrid. Kelly's Blue Book (link -> what-is-a-mild-hybrid-vehicle) in the US lists the different types of hybrid. Considering they rate and write about vehicles all day every day they probably have industry insight on what the differences are.Just for the sake of interest, a 2013 Range-Rover Hybrid is allegedly capable of driving up to 48km/hr for up to 1.6km in pure EV mode using a 35kW motor and 266V battery. It's MHEV and definitely able to turn the wheels
Types of Hybrids
There are three basic types of hybrid systems. We’ve touched on two of them already; however, for clarity’s sake, we’ll briefly describe each below. We’ve also added a fourth hybrid type that’s rarely talked about because it isn’t currently available on production models.
Hybrid (HEV)
A full hybrid system combines an ICE with a battery and electric motor to share the duties of propelling a vehicle. Technically, this is called a parallel hybrid because the ICE and HEV components operate alongside one another. It’s possible for most such HEV systems to propel the vehicle for short distances and low speeds on its own. However, the vehicle’s drive wheels usually receive power from the ICE, or the ICE and HEV system combined. The HEV system is self-contained, feeding the battery with electric output from the ICE’s generator, as well as through the regenerative braking system.
Mild Hybrid (MHEV)
An MHEV is a less grand and more affordable ICE-and-hybrid setup producing less dramatic fuel savings. It’s still a combination of the ICE, a battery, and an electric motor, but the battery and motor are much smaller. Where a full HEV can send power directly to the wheels, an MHEV instead provides a boost of energy to the engine when accelerating from a standstill. It can also manage some of the load from power-hungry systems like air conditioning. As with an HEV system, an MHEV system’s battery is charged through the ICE and regenerative braking.
Plug-in Hybrid (PHEV)
A PHEV can usually propel a vehicle on electric power alone for 25-35 miles. When the battery empties, the ICE kicks in to power the wheels. Although a PHEV battery can draw a charge from the ICE and regenerative braking system, it can also recharge by plugging into an outside source. This plug-in capability, as well as a larger battery array than an HEV, is what allows a PHEV to travel on electric-only power.
Range Extender Hybrids
Think of range extender hybrids as full EVs in which the vehicle relies solely on battery power to spin the wheels but provides a small ICE to recharge the battery when it runs out of juice. That is, the ICE acts like a generator to create the electric current needed to keep the motor running and recharge the battery. The Chevy Volt was a range extender hybrid.
but its little battery was still enough to take out an entire parking tower just by torching of the other electric vehicles around it!Range Rover called it a 'Hybrid', but it is certainly 'mild' with a max speed of 48km/hr and range barely a mile.
they have dropped in value over the last year or so. the value of them went insane through covid (well every 4wd did). my $800 shitbox would probably sell for about $12k at the moment.... it would have be $15,000++ a couple of years ago.Regarding old Range-Rovers: Shane, you'd better start polishing yours ... then you can trade up the family fleet to some EVs and a PHEV for the longer trips.
Spotted one yesterday for a few thousand.they have dropped in value over the last year or so. the value of them went insane through covid (well every 4wd did). my $800 shitbox would probably sell for about $12k at the moment.... it would have be $15,000++ a couple of years ago.
I don't really care about value though .... It's only a problem if I need to replace it!
Pajero at the farm has oil leaking onto the clutch and the clutch is suspect, pulled a tree down which i needed to fall in a spot.
Can't bring myself to replace the clutch on the Pajero.
Land Rovers are easier to work on.
When I did the clutch on my Bronco I took one look at the huge cast iron gearbox/transfer case assembly and decided pulling the engine would be easier.Spotted one yesterday for a few thousand.
been there and done that too. You have to remove the engine mounts and drop the motor down to get to the bolts on top of the bell housing .... and need a huge bunch of 3/8ths extension to get to the rest of the bolts from underneeth.... why couldn't they have just given us an inch of space between the firewall and drivelineWhen I did the clutch on my Bronco I took one look at the huge cast iron gearbox/transfer case assembly and decided pulling the engine would be easier.
Thanks to the Ford's rather large engine bay, I didn't even take the 6 cylinder engine out, just lifted it a bit and spun it around so I could get at the clutch.
The other deciding factor was the gearbox crossmember was secured to the chassis with rather large steel rivets. I would have either had to drill those out and replaced them with HT bolts, or try and maneuver the aforementioned 300kg gearbox and transfer case across the top of the crossmember, and then back in again.
As my fitter and turner son likes to say, "Dad, you've got to work smarter not harder".
No such bellhousing bolt problem with a Bronco luckily, you can just sit in the engine bay and undo them with a spanner.been there and done that too. You have to remove the engine mounts and drop the motor down to get to the bolts on top of the bell housing .... and need a huge bunch of 3/8ths extension to get to the rest of the bolts from underneeth.... why couldn't they have just given us an inch of space between the firewall and driveline
