Autosol polish is very good and a small tube lasts a long time.
Autoglym make good products - their rubber cleaner is very effective and the super-resin polish brings out a good shine for relatively little effort on a sound surface.
If you are dealing with neglected leather then you will want to clean and condition it separately - don't think you can do it with a one application product as it will not work very well. I've tried a few products over the years. I found Connolly's hide food left a sticky mess on the surface, but I understand they went into receivership. Avoid anything with silicone in it as you do not want to seal the surface - it needs to breath. Likewise, beeswax is a bad idea. Straight Neatsfoot oil has a reputation for leaving a greasy residue and sometimes darkening some leathers. Lexol have a modified neatsfoot oil product that may be worth investigating. Suede and aniline leathers require special consideration and care though. Always test any product you plan to use on a small and unobtrusive spot.
My preference is to use Gliptone's 'pH neutral' cleaner to get the dirt off the surface of neglected car seat leather (I quite like their Liquid Leather conditioner too) and then feed it with Leatherique Rejuvenator Oil to improve it. See www.leatherique.com No conditioner will give instant results - it usually takes time and repeated applications.
Among others, in Sydney, Geoff Sara of Jagara Spares (Yes Jaguar parts) should carry the Gliptone products. That's where I got the last bottle about 18 months ago.
51 Captain Cook Drive
Caringbah, NSW 2229
Tel: (02) 9708-0521
Fax: (02) 9708-0523
Leatherique products (Cleaner, conditioner oil, crack fillers, dyes and prepping agents), can be obtained from John Postle ...
LEATHERIQUE of AUSTRALIA (Distributor) Ask for John
The number is +61 2 9880 9911. This is the phone/fax.
Leatherique Australasia Pty Ltd
email: jackpos@optusnet.com.au
Postal address:
PO Box 383 Lindfield NSW 2070
Australia
Caringbah, NSW 2229
Tel: (02) 9708-0521
Fax: (02) 9708-0523
Postal address:
Australia
