Well Folks,
I had a big day on Saturday. My air con expert came over and we worked out a route for the refrigerant hoses and measured what was required for each run, and worked out what fittings would be required to crimp onto the end of each hose.
After lunch we hooked the gauges up to the air con on Dave's BX 16V, checked whether it would hold a vacuum which it did sort of, and then proceeded to give it a camping gas (butane/propane mix) trial refill. It wouldn't pull in the compressor even though we put in 40 psi of gas, so I hot wired the compressor and the radiator fans. With a bit of accelerator and inversion of the camping gas can, pressure built up on the high side to about 180 psi at which level a halt to charging was called - and there was cool air in the car. I later found that the air con temp knob was sitting on the RHS of the pin connected to the slider temp rheostat so that the air con was not even turned on. So a prod with a small screwdriver to move the pin over had it all working with compressor pulling in and radiator fans working in series. And it is still working after three days - how long will it last??
Yesterday I managed to get my heater matrix out so I can make the 90mm air entry hole in the LHS of the air box above. To make room for the air entry tube from the under dash unit, I have to modify the J tube coming out of the matrix either by cutting it off at the bottom or bending it at 45 degrees so there is room for the air pipe to go into the air box above. That way the coolant pipe will go back to the firewall at 45 degrees roughly at the same height as the right angle coolant pipe that goes on the heater tap and back to the firewall. I think my only real option is to use a hacksaw but any other ideas would be welcome.
I went and bought all the fittings and hoses from Ashdown Ingram today and they were all in stock.
Cheers, Ken
Cheers, Ken
