Hi Froggers,
As many already know, I bought an SM just before last Christmas - see post below
http://www.aussiefrogs.com/forum/citro%EBn-forum/120631-another-citroen-has-arrived-family.html
Since that post, I have done a little work and enjoyed driving it to club events over Winter.
I bought 4 new tyres after one started to de-laminate and I found the spare was totally flat and useless. The previous owner put some HiFlys on the front so the car would get its safety certificate. The youngest of the remaining two XWX tyres would have been was 1989 and the XDX spare didn't even have a DOT mark on it. I saw on the SM Wiki that 205/65 R15 tyres helped to long gearing of the SM around town and I managed to get 4 x XM2 V rated tyres of that size for $346 fitted. The difference in ride, grip, lack of noise and steering was amazing.
I fitted some inertia reel seatbelts which work OK but still need some fine tuning in the medium term.
I have just put the SM up on stands to get on with some projects.
Project 1 - Re-aircondition the SM in RHD configuration.
I have fitted a SD5H14 S6626 compressor on some home made brackets and it is now belted up to the HP Pump.
I have trial fitted an evaporator unit into the LHS footwell and I am working on a ducting system to feed into the LHS of the air box. This will involve removing the heater matrix, cutting a 90mm diameter hole in the airbox, changing the config of the return pipe from the heater matrix so it takes a 45 degree route back up to the pipe to the engine and getting it all back together.
I have reconfigured the eyeball vents so I can get ducting from the evaporator to both of them.
I have fitted a plug and play series/parallel two speed radiator fan control system and have a two contact coolant temp switch ready to fit to the radiator. A trinary aircon pressure switch will parallel in with the coolant temp sensor.
I have a condenser and receiver drier ready to re-fit onto the Radiator and I am about to drain the cooling system to take the radiator out. Luckily there is a good description of how to do this in the 581-1 instructions about taking the engine out. Any extra things to be aware of here would be appreciated. However, I think my radiator and hoses are all original so I hope it all holds together OK.
Then I need to get the refrigerant piping between the compressor, condenser and evaporator fabricated and fitted. I will initially try HyChill refrigerant and see how that goes.
There are also some other projects I will do at the some time and I think it will be easiest if I take the LHS wing and the LHS injection manifold off the car. Any thoughts here would be appreciated.
Project 2 - Replace the original style oil cooler hoses.
I have some new hoses and O rings but I would like peoples ideas on whether I need to precharge the system with oil before reconnecting to the engine and if so how I would go about this.
Project 3 - Replace the membranes and recharge the hydraulic drive for my RHS directional headlight - I will follow Citrothello's slide show to attempt this with LHM rather than the original Glycerin solution.
Project 4 - See if I can get some headlights re-aluminised by HyQual in Caloundra.
Project 5 - Replace the gearchange cable. There is a lot of lateral slop in my geachange and 2/3 of it seems to be in the cable. The gearbox mechanism seems to be tight.
Project 0 - Continue to try to get my clock working. I have had one go at this and some clock oil helped at first. But the bottom bearing on the balance shaft seems to have failed as it is very sloppy. I have a CX clock working like a dream on my desk at present and I think this mech will transfer onto the SM dial system when the dash comes out next.
Any comments, hints and ideas on any of these projects would be appreciated.
I will add posts to this thread as I make slow progress. Let me know if you want pics or more explanation of any of the above so far.
Cheers, Ken W
Cheers, Ken W
