is it a forge ?Lake Goldsmith....
blower drive still to add.....
Favourite hearth with the home made set ups looks to be a truck brake drum, this one is bit flasher.
Bob
Bob
G'day Shane,is it a forge ?
That is a centrifugal switch, that switches out the start winding when the motor gets up to speed.View attachment 205868
I spotted this pop up yesterday on facebook marketplace. It was being sold as needing a new motor ... but the motor and all the bits to attach it were still with it in a box. The owner had tried to get the motor fixed/rewound or replaced. but had been told it would take months to get to. So he just threw it in the corner of the shed and forgot about it.
I chucked a 3 pin plug on the motor and plugged it in ... thinking it'll probably work if I spin it as it'll just need a start cap ..... I plugged it in ... it started spinning, then with a "bang" blew a shower of sparks out of the back of it and popped the sheds circuit breaker... hmm.... I can't say I was expecting that...... Its a bit strange as it doesn't smell burnt in the slightest.
Hmm... looks like its short against the top there.
See the screw, its shorted there.View attachment 205874View attachment 205875
There is a centriple mechanism here for some reason ... and its missing a spring on one side..... Arrrhh.... got it Its over expanding and shorting. A quick drive up to bunnings to find a suitable spring to cut down .... Fit it up thinking "fixed" ..... she starts spinning "Bang" ... sparks out the back .... circuit breaker gone again .... Hmmmmm
So I pull it back apart, I need to actually understand what this is doing.
So the weights are being thrown out and pushing the center up againt this top cap. Which pushes that big ring up (which turns out to be a contact switch for the wiring to it). So i followed the wiring and found the start capacitor. Ok, this makes sense. The start capacitor circuit is closed while the motor isn't spinning, once it spins upto speed the centripetal weights are pushing the switch open. only the weight mechanism is managing to touch the switch plate contacts and short it out.
So I played around with the centripetal mechanism and found it was loose on the shaft, the grub screw is slightly loose and its moved down the shaft. So I pushed it back down the shaft, tightened the grub screw and the motor worked straight away without the shower of sparks and bangs
Yes there should be a spring on each side as you have worked out. There also looks like a screw between the rotor and the switch. Has this come loose and the switch moved up the shaft causing the shorting out problem that you have?
It would also be wise to remove as much of that carbon as you can from the windings and also from the switch to stop more shorting issues down the track.
Here is a link that will help explain what a centrifugal switch does:
That machine will be fine for your needs, Shane. I have one much the same. The only issue is you have to watch the small thin blade doesn't drift off course. The bracket with the long crew is an adjustable stop for cutting to length.
Roger
That'd make a darn good shed heater I reckon. Put a coffee brewer on top and some pied in the over, bring a swag and you'd never have to stop working on cars.
Yes, once upon a time I was one of those someones; short wood for the stove, long pieces for the two fireplaces.a lot of wood splitting work for someone
Hi.Do any of the old fogies ( ) here know how this thing works? Some is obvious, but there is a lever that moves a flap inside that I have no idea about. And why would you want to pull the front off the flu ?? .... And fill your house with smoke ... hmmmm
Yes, damper on the base of the flue for starting.Hi.
We had an identicle IXL in our family farm house, but with the black enammel with white spatter marks. My grandparents had an even older IXL model.
We used to cook field mushrooms in butter on the hot plates, yum.
The rectangular slot beneath the oven, we used a long poker with a right angle flat end say 17mm wide, to rake the ash out of the slot.
The lever beneath the RH corner of the oven, is a damper that directs more hot flue gas to either the main oven or the lower plate warmer.
I can't quite recall, but I think the damper in the bottom of the flue was used for lighting the fire, not sure on this.
Ours had the hot water tank adjacent to the fire box to heat water for the gravity hot water tank. No fire, no hot water.
Cheers.
