I found some under Hotelectric (note -without the rod)none of which are fit to link here:nownow:
As if I already don't waste enough time on YouTube.
Is this the ultimate Citroen mechanic's tool?
No! The head is not sufficiently persuasive.......................
My clockwork brakes are leaking and the manual shows a special tool (2129-T) to release? the pads, which I don't have. Could someone please post some measurements, or even a picture (cross section) so I can make one up, thanks.
I have had a floor hoist for some time, but it has not done much work.
I found a rubber plug halfway up the hydraulic thinggie, for topping up the oil. I removed the rubber plug, opened the valve to lower the boom to its lowest point and added hydraulic jack oil to the hydraulic thinggie and the hoist came to life:-
Sphere removal tool.
After almost 45 years of trying all sorts of tools to take difficult spheres off.....
This is it. View attachment 131068
If you have other sized spheres, it would not be difficult to make one for each size.
A bit of 25x3 flat for the strap.
A bit of 40x6 for the handle.
2 M6 bolts 35 long with nylocs.
A bit of bending and cutting,
2 dabs of weld. Done.
