Well finally got a chance to take it down the road for an inspection, (Thanks David, that guy you put me onto is great ) and there was a few bits I missed
Trailing arm bushes on the right wrecked.
Steering rubber (universal joint) is really split.. (oops)
Plate lights no work (front and rear, could have sworn they were working..)
High beam switch broken.
That last one is a bit of fun. when I say broken I mean activating high beam will cause smoke to billow from the wires under the steering column. To the point where I'm a little scared to touch anything else for it might decide to burn itself to the ground. Having said that it's nice to know I have an electrical fire on demand should I require one.
So as I wanted a POS, well it might not to be to far from the truth
I'll fix the rubbers in the meantime and think carefully about replacing / removing the electrics...
Also, previous owner had removed the window sprayers and just installed "bolts." I had assumed window washers might have been a luxury item back in 1971 and didn't bother looking into them. To Super Cheap.
And Kenny, did you seriously never turn on high beam whilst you had it? Didn't you put fancy low current bulbs in it?
And as usual, this place is amazing.
We'll time to take it apart and clean it and see how it goes,
The inspector was also upset the springs had failed in the switch, ie. there was no resistance flicking the lights from high to low beam, but that should be pretty straight forward.
Good news!
FFFFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUU!
Thank you mystery Ute / high bumper bared 4WD.
Pull into my street coming home from work and I'm like.. wait a second! *sigh*
At least they didn't destroy the indicator globe. That's a plus. And I suppose that makes up my mind about the parking stripes.
