p.s. Don't let the alternator drown in LHM as it will ruin it. If it retains the original unit, it's not used on other models and is expensive to buy. However, you could fit one from an early C5, but it may be a lower output.
The good news is that the alternator situation is not quite as restricted as that. Although the original Mitsubishi with PSA part # 57051G is marked NFP, there should be alternatives, as the same alternator is specified in Servicebox wherever the ES9J4 or ES9J4S motor was used. There is also a 120 amp alternative, although my preference would be to stay with the original 150 amp specification.
In addition to the XM, V6 Xantias, early V6 C5s, all 406 SVs, late 605 V6s and at least the early 607s all used this alternator. onlinecarparts.co.uk lists 8 suitable units from 6 different manufacturers, ranging in price from 164 pounds to 648 pounds. However some are exchange units, there are 3 different pulley sizes among the 8 and none are in stock .
So the basic thrust of your post remains - they don't grow on trees. If I get really stuck, I have a 406 here which I know has a good alternator .
Alec
