Right, time for a new chapter.While waiting for a few bits and bobs, thought I'd have a look at spark plugs. Shouldn't be any problems - plenty of power and excellent fuel economy...
Got the coil pack off OK, then - Oh Dear!
Counting from timing belt, first well has a little oil, 2nd has quite a lot, and third is flooded. In the RH well the oil is high on the spark plug tube on the outside, and up to the top of the plug insulator inside the tube. Is this the result of cam box leaks? I suppose the only other option would be a major spill while topping up the oil, but this is not clean oil straight from the bottle...
Suppose I'd better get the inlet manifold off to see how bad the other bank is.
Sigh... - Mike (previous owner) did warn that cam box leaks still weren't fully fixed, but I was only thinking of external leaks, and it doesn't look too bad at all on the outside of the engine.
Someone mentioned that someone (in England?) is producing gaskets for these cam boxes - does anyone know about this? I guess I should put this in Pug forum as well, as D8 406s use this engine.
Alec
Call me lazy ... but that doesn't worry me in the slightest. It'll drain nicely each time you do a plug change It isn't unusal for DS's and CX's to have a little oil in the tubes as well (you are just relying on a simple rubber seal with them).
