He's a real joy to watch. So much skill.
Previous owner might have used rivets instead of screws? Either way...... eventually someone agreed with Citroen factory that the safari wing was a bit more of an impediment to wheel-changing than the saloon was, and took them off again.Not sure that was it as I found one broken rivet in one of the holes (ie no distortion from screws) but ultimately doesn’t matter - won’t be adding infills… never seen a photo with them in. Would make it look quite rear heavy I would think.
I don't mind it. Don't have Photoshop so I grey scaled it cause I reckon the bright colour doesn't do it any favours.Found a photo on Dr. Danche’s nuancierds website… yuk, would look terrible with infills…
Hello, NiceDONE! All outer panels’ rust cut out, sections fabricated and welded back in. This wasn’t as bad and lengthy as the chassis work, but I won’t miss the dirt from the grinding or the fumes from the welding…
Practice makes perfect. I got better at fabricating door bottom sections. Joining two sections is easier than trying to fold up four angles…. Then add the end sections and drain holes. A skim of filler will cover any sub standard welding.
View attachment 134877View attachment 134882
One of the front fenders was rusted behind the bonnet lock holder. A fiddly job with a number of plug welds to recreate.
both front fender’s rear bottom sections were also a little rusty, but not too bad and easier to access and fabricate than the door bottoms.
And there they are: All 10 panels - ready for the last step of filler and prep work. Slowly getting to the pointy end of the restoration.
Never thought I would enjoy cleaning up the work bench after weeks of grinding . Pack up all the tools, vacuum the whole garage and benches in preparation for the next stage.
Question for the Safari anoraks - my rear panels have a number of 3mm holes in them. They look like they may have had a trim riveted on or something like that… was that ever an aftermarket option?
Also got my rims back, with nice new Michelin X 165x400 tyres. Expensive exercise, but they will last a few decades…
And another brains trust question: A mate of mine sent me a couple of “period correct” accessories…
A foldable fan style sun visor and a Korean made Galaxy 206 radio. Does anyone know what year those are from? Even roughly? Surprisingly Google doesn’t show anything at all on the radio…
Unlikely I will use them, but let’s see whether anyone knows anything about those items.
View attachment 134878View attachment 134876
Happy lockdown 5.0. Hopefully over soon…
Sven
Stuckey Tyres in Brunswick / Sydney Road. About $400 each incl tubes and fitting.Hello, Nice work! Could you tell me where you have bought your tyres from?
