They normally have the release pressure stamped on them, 4psi or 28kpa.Not sure what radiator cap I have… how can I tell? Maybe I had the radiator too full and it just overflowed a bit to balance.
I will change the condenser and might get a new coil - would anyone know the model of coil I need?
I changed the old plug leads to new ones, new cap, new finger - so that should all be ok.
I will check valve adjustment as well, just to make sure it is all set up ok and check the plugs.
Let’s see what tomorrow brings. If it starts and runs fine first thing it is definitely heat related.
Should be just a standard non-resistor 12V coil?
Hotrodelectric should confirm this?
