I think we all need to get him another car ..... What are we all going to login to read each day now
Perhaps modify it a-la a bubble-roof Abarth?Sven,
Find someone that has a SM nearby (jonf maybe) and go have have a sit in it. The roofline is much lower than a DS. I am 183cm and my hair brushes against the headlining when I have the drivers seat right down on its lowest position and I also drive with the seat back as far as it will go. There is not much space between the back of the seat and the squab of the back seat.
Cheers, Ken
See, that’s the brilliance of the froggers - 5 min and a few good leads - thanks gents. Didn’t touch the coil immediately after stopping, but I didn’t put a new coil or condenser in, so that could be a possibility.Coil/condensor problems often show up when hot. It may well run fine again once its cooled down.
I am pretty sure the dizzy set up is right as I checked it a number of times - the slot was parallel with the block and the larger half round was ‘the right way’ (just don’t recall which was that was now…)Does the dizzy rotor line up with the cap contacts?
Take the cap off, turn the engine over until the points just open, check that the rotor is pointing to a cap contact.
It's possible that you put the drive gear in a tooth out?
This is probably not related to the poor running.......See, that’s the brilliance of the froggers - 5 min and a few good leads - thanks gents. Didn’t touch the coil immediately after stopping, but I didn’t put a new coil or condenser in, so that could be a possibility.
How hot, not sure, but hot enough to push maybe 200ml out of the overflow and the top radiator hose was pretty ‘hard/pressurised’…
Should be, what, 8lbs?This is probably not related to the poor running.......
But, you have got a low pressure radiator cap on?
No, early ones were only 4lbs...... I think still that in '64.Should be, what, 8lbs?
A misfire will contribute to an overheat condition.
Sven, I just saw the video on YouTube. Ensure the cap has no cracks or carbon tracks, that the wires are good, and that the plug insulators are in place.
Yah, I knew it was a very low pressure. Most all my experience is with the later (68->) cars.No, early ones were only 4lbs...... I think still that in '64.
Mines a later one with the recovery bottle on the inner guard. It probably displaces 500ml into the bottle then sucks it back in when it cools.How hot, not sure, but hot enough to push maybe 200ml out of the overflow and the top radiator hose was pretty ‘hard/pressurised’…
