Thanks Graham, thought so.Yes...
Sent from my HTC One M9 using Tapatalk
Thanks Peter, you know, I remember you saying to put a smear of threebond under the liners when putting into place. The only way I could work out how to do this was to have the piston in the liner before it goes into the block doing it two by two. Your image confirms this. I will do this tommorow night and the clamp them all down at the same time.Some pics for future reference.
They are new bolts - so do I just continue with 300 deg? will gasket be ok?
Is there a brand of bolts that is preferred?No, how do you know how many degrees you have tightened them already? Gasket will be fine. Better to get another set of bolts and either tighten to high 60s or angle tighten to 300 degrees.
