17-07-11
...well I had hoped to get into some panel work this weekend, Brisbane has been magnificent perfect for DIY painting, but the weekend decided showers were in order
Always plenty to do, picking up from last week I picked up a few bits and pieces from DS Motors, plugs, rocker gasket, tube seals, plug insulators - also scored a new Ducellier ballast type coil on ebay. So reassembled and tidied and fixed wiring using the proper rubber straps... I need to get a clamp for the air-cleaner hose and one of those star dividers for the spark plug leads.
The motor is sweet with this TLC, starts and runs as steady as a rock. Though I am saving for a 123 ignition :wink2:
Moved on to fitting the replacement sill kiss rubbers, I can't believe how much these improve the appearance. I guess they are also practical and should help seal the closed door from dust and damp.
Old rubbers were shot, thin broken and brittle...
New rubbers sourced from Geert at Citroworld, these are a superb reproduction, fitted with new stainless self tappers because I wouldn't want the next custodian to go through the same dramas I had removing the rusty old fixings :wink2:
Maybe some paint next weekend
