GreenBlood’s D(very)Special Rejuvenation 2009>
Lamoor,
Since that post I have been in contact with Greg Fienburg who is happy to be named as the one who has brought these stalks back to life. He needs switches that are fully functional, he removes the stalks and has them chromed, replaces the ends with new (not painted) re-assembles and bench tests. The process can take a while to complete a full set with parts sourced from OS, but for me with the car off the road it was well worth the wait.
Contact Greg on doublechevron(at)bigpond(dot)com
BTW, the dash I'm using is the one I bought from you, it has since been stripped and powdercoated in a finish very close to original. :)
Surely that there would be my email address :roflmao: :clown:
Terrific work Chris !
What an enjoyable thread to follow.
best wishes
Ramon
Today after a long search and an even longer wait, a parcel arrived with 7 metres of vinyl to re-line the roof, C-Pillars and rear window hoop (a little extra to line the sliding sunroof).
<Snipped>
Hi Chris,
Can you share with us all where you obtained the material from?
I have a '61 DS19 which needs these items recovering and you appear to have found the source!
Regards
Mick
Hi Chris,
Regards
Mick
Hi Mick,
I'll try to type this with a Yorkshire accent :)
The vinyl I'm using was sourced out of the USA, but you may find a local supplier - it is a reproduction of a VW vinyl used in the '60's
Go Westy
1119 Los Olivos Avenue, Los Osos, CA 93402
Product code: GVW-Basketweave Vinyl - Colour: Off White
http://www.gowesty.com/ec_view_details.php?id=2794&category_id=&category_parent_id=
The Off White in reality is a beige(y) light grey, it looks dark when you see it in the flesh but in situation it is remarkably close in colour to original.
Really good people to deal with, very prompt and for my money quite inexpensive. 5 metres delivered to my door for $210.00
attachment.php
The other option you should explore is via Citroen Classics in Middlesex UK
Darrin and Kris Brownhill, nice Citroen people who I believe have a product that also looks close to original.
http://www.citroenclassics.co.uk/
The only drama I have with the vinyl I have is that the weave is at 90 degrees, where the original lining was 45 degrees, the width of the roll won't accommodate a 45 degree twist. I can live with that as nothing else I'd seen came close. The VW stuff is very close in colour, depth of texture and the size of the weave.
I'm not familiar with the lining on a '61 DS19, you may need samples before committing, I'd be happy to send an offcut if needed?
I would love to hear more about your car, very rare indeed in Australia and no doubt the UK - if you need inspiration and haven't already seen this site be prepared to spend a good few hours drooling - this is a superb restoration of a '58 DS19
http://www.hjulius.com/Hjulius/Restoration.html
The dash chrome kit is available through Greg Fienberg, $80.00 plus postage doublechevon(at)bigpond(dot)com [no relation to our very own Double Chevron]
Hi Chris, I'd love to get one of these kits for my car (much in need) - can I just check that email address? is it doublechevon or doublechevron (with an r)? thanks ali
oops, yes that should read chevron :)
thanks Chris ;)
I've been getting a few things done lately (dashboard is back in) and it's made me realise how crap the dash actually looks. the chrome kit should smarten things up a bit
Long time between drinks
It's been a while with little to update here.
Finally managed to scrape up the readies to purchase a Retrosound Model 2 headunit. Now fitted to the dash, pretty well ready to re-fit into the car.
attachment.php
Over the last month I've been working to get the sunroof re-lined ready to refit to the roof (once painted of course).
This has been a little epic, my advice if you have the money get someone else to do it. Fussy fiddly frustrating job.
First task is to separate the inner lining from the outer, everything is pop riveted together. . .
attachment.php
This is the old lining released from the outer, a velour lining that served for 10 years or so but typical of velour the inner foam has turned to dust, the outer is threadbare.
attachment.php
The bows, rivets drilled out and released
attachment.php
attachment.php
The old lining freed from the frame.
attachment.php
Relined with new foam.
attachment.php
The replacement lining, vinyl supplied by myself and fabricated using the old lining as a template by Lee Brothers here in Brisbane. Took a while but Warren has done a masterful job, also supplied me with foam and glue for the main part of the roof lining.
attachment.php
attachment.php
attachment.php
Fitting new lining, starts at the front and work back.
attachment.php
After much cursing, re-assembled the inner and outer and re-fitted to the frame.
attachment.php
Refitted the handle trim and voila!
attachment.php
attachment.php
Probably not much use to many of you but anyone with a Webasto or Britax sunroof may find this useful?
A couple of useful links, most parts are still available out of the UK.
BRG - Britax sunroof rebuild.
Page 2
Next? Get the roof painted and re-fit. . .
Looks insane Chris... all your work is always so neat!
Matthew :)
Matthew :)
Thanks Matthew,
I can tell you it nearly drove me insane :crazy:
It's like a Rubik cube, pulling it apart is straightforward - putting it back together has to be done in a sequence and I confess to moments of. . . well let's just say I might have let go with a little foul language and was not pleasant company for a while there :clown:
Since the photos I have made a couple of small adjustments and removed a couple of puckers ( I said puckers :nownow: :clown: ).
Good to see you back, the 'DS Appreciation' thread could use an injection of mnm, how many pics of Ds with ragtops have you got stashed on your machine?
Thanks Matthew,
Hmmmmm... I could come out of retirement on the DS Appreciation thread... just for you. We'll see... I would have liked to have been a fly on the wall to hear your expletives.. :D
Matthew :)
Now I know why you want me to fit the new interior blind to the sunroof here and use it :roflmao: It sounds like a "fun" task :clown: Luckily it doesn't need the interior part replaced if used :)
Very nice.
If you need another pair of hand for the re-fit the roof, let me know. Mrs is overseas until end of June :banana:
After that is ok too.
Very nice.
I'll be sure to sing out when I'm ready - how's this weather for painting haha ha ha
If you need a roof to practice on there is always my Black/Grey BX?
I cannot wait to poke around this car at an FCD in the future, your attention to detail is fantastic!
Always looking forward to new stories and pictures!
1/08/2013 Dash refit
It's been a while so a bit of an update - today the dash has been re-installed, the delay has been with getting a few extras and making sure everything fits and works before assembly.
I've had the head unit for a while but I wanted to run it via an external amp, Ive gone with a Response class AB 4 x 100WRMS from Jaycar. Finding a place to mount was a bit of a challenge but it found a neat home under the rear parcel shelf. This of course meant running power/trip/RCAs and front speaker wiring to the front of the car and up into the dash.
attachment.php
The rear speakers are 6 x 9s, front 4" also from Jaycar
attachment.php
attachment.php
attachment.php
The head unit wiring run, all the wiring/switches tested and tagged.
attachment.php
attachment.php
attachment.php
With the headunit providing handfree phone calls I wanted a decent phone mount, this is a Brodit, it has a direct USB connection to the headunit for both in car charging and playing music stored on the phone. It also has a windscreen mounted antenna to boost phone signal strength.
attachment.php
The other little modification has been the addition of a choke warning light. I ordered in a new choke cable from Citroworld and when it arrived found it had a built in switch.
Wired switched positive to one side of the light, the other side runs to the switch and after some head scratching I discovered the cable itself grounds once conected to the carby.
attachment.php
attachment.php
attachment.php
With only a couple of millimeters of choke the light will illuminate.
attachment.php
All back together, quite a transformation :)
attachment.php
attachment.php
A good line of sight to the phone when used as navigation etc.
attachment.php
. . . and a little tiz :clown:
attachment.php
I need to fit up the aircon evaporator and vents, and get that working at optimum, but pretty happy with the look and the added creature comforts that should make driving as daily a little safer.
Looking great AND with practical creature comforts - great job going on here Chris. Looking forward to seeing it back on the road one day.
There are plenty of GPS speedo apps for the iPhone. That will be a good place to watch those to.
