Measure on the flat side of the tooth. This is the driving side and set the angle of the gauge so that it is a right angles to the surface of the tooth. At the very edge of the tooth it will be almost at a tangent to the circumference but just a little bit more. Do you have a measuring base block with an adjustable rod mount? Old Dan Jones used to set this with a strip of thin paper. The idea was that if you could pass a strip of paper through the mesh of the CW and P without it cutting through the paper the mesh was very close. Depends upon the thickness of the paper. You could try this after you have done your adjustments. I would try using grease proof cut about 2 inches long and 1/2 inch wide.
You could also confirm the conic depth setting using Prussian Blue engineering ink. Oil paint from a local art supply will work well. The print should be evenly spaced along the length of the tooth and at about midway up the tooth flank. With a worn setup as yours is the contact will be quite broad. Wash off residue with turps!
