Now it needs a long distance run to sort it out!
Camperdown sounds good!!!!!!
I would not count on the lower joints being good. I do however have all the necessary tools to dismantle them as well as the uppers. They may be salvageable.
425948 is the outer oil seal.I was just going to tighten the hub nuts up and assemble the ball joints for now (so I could move the car around ... drain the fuel tank ... all that exciting sort of stuff).
Everything on this car is so obvious if its "not right". Look where the hole for the split pin is versus the nut. Either there should be a spacer behind the nut .... or behind the drum.
I've got to be missing 425948 .... I'll find out later. Its a pitty I just torqued that bloody thing down to "as tight as I can get it". It'll be a lot of fun to get that damn drum back off!
I think my father has a box of driveshaft bits "somewhere"... so I'm guessing we'll have any missing bits ........ if I can find them
Correct! There are too many threads showing. Also the split pin hole is visible even though it is partially covered by the nut.actually ... now I think about it ... no. Its got to be the taper is pulling through from a worn driveshaft taper..... hmmmm
Shane, please don't use that stale fuel in any mower, even a two stroke , especially a Victa with the plastic carburettor. It can dissolve or make plastic parts & seals either dissolve or go like chewing gum. Can kill garden weeds though !!!The petrol makes me feel sick and makes my eyes sting just being near it! Its the sort of fuel I don't mind using in a 2stroke mower ........ and nothing else.
