Well that explains the confusion on my part Artificer has a slough car. This one is french built ( squiggly door handles, metal dash, painted grill). My father found it in one of the old CCOCA magazines back in the 70's. It sounds like its been off the road for at least 40years. The listed owner was the father of the person it was purchased from. Apparently these were delivered in undercoat to Australia and this one was painted a chrysler red on arrival.The only flexible lines ( hoses) are the ones shown in the above pictures and the ones to the front brake cylinders. Slough cars have three flexible brake hoses and Paris cars have four. All other lines are solid fixed lines originally sheathed with a wound steel wire, encasing the outer of the pipe. They are not designed to flex! In my installation above I elected not to renew the wound wire casing.
If I stick my head up under the dash, you can see the vent assembly is there ..... Yet it has been filled over. I'm betting that is why the battery tray and floors aren't rusty. I wonder if leading this vent panel shut was a dealer thing when the cars were new (I'm assuming its leaded shut as its not ghosting through the paintwork like it would if it was covered in any sort of filler).
The car also has the sunroof frame fitted under the roof lining. Its interesting the way they built cars way back then.
