French Lemon is quite acceptable atm. Still goes into sh!t mode occasionally and randomly, but at least it's now easily fixed with clearing codes which actually don't show up.
Only goes into sh!t mode when sitting in traffic, or crawling in gridlock. Water and oil temperature makes no difference.
Yes I'll try and do this tomorrow But I think your throttle is all OK.Can you do me a favour, next time you play around with Torque pro or diagbox, can you please record your min/max throttle values.
Both in terms of % as well as mV.
Could you do the throttle % first, when engine is off
Yeah they did this too, that solution is also on the invoice !PSA dealers have a liquid solvent for cleaning the inlets. You spray it on and leave it to soak to soften the deposits. It can be bought as a spare part.
Here's the full deets, valve cleaning juice and granules are down the bottom :what the part no. of the PSA solution?
