Have another drink BowieI'm really enjoying your under arch colour.
I'm trying to decide what to do with mine, black or body colour, bit now I want the body colour.
Thanks a lot you jerk.
And keep taking the pills of course.Have another drink Bowie
More painting today after work.
That bitumen that you talk about is white on my R17. More like polyurethane.
View attachment 123326View attachment 123327
Fanta?it looks delicious!
Yes it is Sunny. And you're about black on the front guards. I have two here from Angru that have the black pitch.Is the white just in the inner guards at the rear? As on the cars I own and have worked on I have never had to touch the rear inner guards as they have always been well painted. On one car I did respray the inner guard but have never cleaned them off. The front inner is black undercoat though.
You are more conscientious than I am, that's all I'll say. Wow..... You could regard it as protective of course.What's the best way to tidy up the fuel and brakes lines? They are coated in dirt.
They're hanging down from the car. I just want to do what I can where they are. Just a section. See post 805Hit them with a high pressure washer and some detergent degreaser then paint black glup over them.
Cleaned the bolts and some fittings with a hydrochloric acid bath, small wire wheel and a treatment of rust converter. Another job done. They will need some etch primer and epoxy black.
Painting is finished underneath too with two thick coats. Can't wait for the axle and brakes back plates to be powder coated.
Still to do list consists of painting the floor of the boot in 2k, clean and paint the sway bar, clean the bearings, clean the brakes parts, drums and paint. clean the brakes lines and the fuel lines.
Definitely better than new! I'm pretty slack in these matters by comparison. Bit of a brush down, a quick spray with Fertan and then etch primer and top coat, not 2K and this is only recently I must admit. I tugs me forelock.....John that is going to look better than new underneath at the back.
John, that fertan, I don't like sorry. It washes off if close to water when tested and is supposed to be wiped clean?? The bondall does not. When dry, it works well as a primer ready for etch primer. I had my Atco mower parts sitting for ages with this Bondall converter coated and it just works. It goes grey in colour and sandable to smooth out. No moisture over a winter even affected it. It got coated with etch primer and 2k top coat. The proof.Definitely better than new! I'm pretty slack in these matters by comparison. Bit of a brush down, a quick spray with Fertan and then etch primer and top coat, not 2K and this is only recently I must admit. I tugs me forelock.....
