Looks good John. That's nicer than under the front of the R8 - I'm finding a couple of patches where I replaced areas of rust damage in the 1980s with small galv panels, Fishoil and self-tappers. Just a hint of structural rust where it probably doesn't matter too... The 17 was definitely better built.Dirty rotten job. Wire wheel to surface clean 47 years of WA dirt. Found a bit of surface rust where the brake controller is fitted. Must of been vaping at some stage. Not too bad really and treated with rust converter. We will continue...
View attachment 123209View attachment 123210View attachment 123211
I've finally developed a method of cleaning 56 year old coil springs for painting. Belt sander belts, turned into strips and then cut longitudinally into 1-2 cm strips, then reciprocation, wrapped around the coil and working along the wire from end to end, then upside down and repeat, then along the outside of the spring. So much brown dust - I could barely believe it! I must be getting slow - took a couple of weeks to think how to do it...... Rust converter on today, primer tomorrow by brush.
