Well well,
I ended up buying some cam brake in lube, used about half the bottle since the SAE30 break in oil already has high ZDDP and I didn’t want to kill the cat. It flows like honey so you’ve got time to crank the car before it drains back down.
Quarter of the bottle, cold crank with no spark and about 20 seconds later I was getting oil to the head…and down the back of the engine. I quickly learnt that the rocker cover serves the dual purpose of keeping oil in, and holding the spray bar in position so it needs to be pretty tight.
Matthew came over today for its first start. Poured on another quarter of a bottle of break in lube.
Took maybe 5 seconds and she started with oil pressure at the 3/4 line @2000 (it would sit around 1/2 before, so the 6bar spring is doing its job, thank you Matt).
Held it between 2000-3000rpm for a good while before we were confident we could take it for a test run. Got to the first hill and immediately it started pinging so I took it straight back.
Cue: “I told you so”. I expected as much as it had old 95 fuel and I had the dizzy set to whatever alignment was stamped in.
I don’t want to have to suck the fuel out so might give octane booster a go first. A timing light is in order too.
All in all a successful day. No fires and it started first go, apart from forgetting to connect the AFM to begin with.
