Just be wary, the head moves around when you torque it down. Thus, by all means do a rough shim on the bench, but you'll need to do it again.My head guy he said get the cam first and he can do everything including replacing the guides, buckets, shims if needed.
I'm going to be the guinea pig for JB Weld Original. I just couldn't justify $280 for a tin of Belzona when I only needed a fingernail amount and I still wouldn't trust my workmanship enough to not use a sealant. The Devcon equivalents exhibit similar characteristics to JB Weld but have a much lower temperature rating in their specs.What epoxy did you use in the end?
I've got Warren & Brown torque wrenches, but I'd love one of those new jobbies that does angle AND torque.Come and borrow mine, old school but accurate and reliable
If only someone told you earlier.I'm going to be the guinea pig for JB Weld Original. I just couldn't justify $280 for a tin of Belzona when I only needed a fingernail amount and I still wouldn't trust my workmanship enough to not use a sealant. The Devcon equivalents exhibit similar characteristics to JB Weld but have a much lower temperature rating in their specs.
Are you suggesting a Warren & Brown isn't accurate? Far out you're a wally.What I read on the internets at some point was that clicky type torque wrenches were not adequate for aluminium blocks, probably because they can overshoot the torque or maybe because they are not that accurate to begin with.............
.......................You may get away with that sometimes but I don't think you want to do it with such a high torque in an aluminium block like the XU9.
