Unfortunately not Peter. Cannot install until the door cards are fitted, which cannot happen until the final door alignments etc is completed.Sounds like a fiddly job but they are very obvious sitting in the car.
Mike wins by about 4 years.A great find of that kick panel card. Probably not the easiest stuff to come by.
It's shaping up to be bit of a race to the finish with yours and Mike's restos. Who will win?
Dano said:
Mike,
Are your hand-brake cables really tight/taut. I've used new cables throughout and there is very limited cable movement. All cables are wound back as far as possible and the brake shoes have been adjusted to the slackest setting.
Just seems strange.
Any feedback would be appreciated.
Dan
hi Dano, if I recall the handbrake outer cable lower mount clamp is a variable to cable travel as it can be loosened and outer cable steel pipe can be moved forward or back to be another point of cable adjustment.so depending where clamp is positioned on outer tube will effect positioning of adjustments at cables..... ..jim
No rear trims.The front screen trims are aluminium and they are very flimsy. Knowing how to do them properly now, hopefully they wont bend.
As for the rear screen, I don't recall any Australian model having trims. I'll stand corrected. Parts manual doesn't list them(?)
Depending on time, I may give them a crack tomorrow.
