Some seriously impressive projects
Thanks guys. In terms of shear size, bulk and weight, this grader has been the most difficult to manage.View attachment 129527View attachment 129528
Oh, its a massive box blade! I didn't pick that. The box blades I've seen just get picked up by the linkage! Interesting design. I wonder if the fact its towed at a distance rather than attached by the linkage allows it to level better.Nice! I like the gusseting. The rocker axles will be good for evenness, and the tilt design is clever. What is the purpose of the alternative attachment point near the rear of the tilt ram?
The spare wheel is surely overkill.
It would need 100 hp to do it justice, maybe 150 hp. Any more might be a little unkind.
Shane, it's not a scraper because it doesn't carry the dirt.
Roger
and collect a hernia as well....He could keep in in the back of his farm ute for repairs around the yard (its a travel case)
But he could use the toolkit to fix it - it’s not hard, even a surgeon can do it.and collect a hernia as well....
Bob
The big question: what's with the combination spanners. I mean 9, 11, 15 and 16 mm? They're just getting rid of unwanted sizes.
Have fun,
Rob.
Enjoyed our tour of some of that equipment Roger. On the subject of multiple tools owned and never finding them, as one gets older I find a necessity after using tools and even if dog tired from the effort, take the time to return them to where you would expect to find them. I could never get that prepared or organised enough to create shadow storage boards for each individual tool ( I envy those who are so pedantic and perfect in that every tool has its perfect place) but I do have old steel cabinets with long drawers to store say big screw drivers and smaller screwdrivers and another place for micro screw driver sets.They're only Kincrome, might be OK for someone who wasn't a tool snob, good value if that's all you want or need.
Down the paddock I can usually fix most things with the hammer, fencing pliers and 12 inch shifter I carry in the 4 wheeler.. Plus fencing wire and hayband. Round the yard I just raid the workshop for whatever I need. unless its still where I last used it. Sometimes I wonder how a bloke can have several of the same size tool and not be able to find any of them.
I'm a barber surgeon at best, didn't study that stuff long enough to qualify and ended up getting the title Jill Biden style.
And yes, running a farm on my own I have accumulated an extensive collection of equipment to lift and move stuff.
Roger
Well, I recently put in a set of pull down attic steps. All the stuff rarely used is in the ceiling I lined with 16mm composite board. Like the air compressor, 3 or 4 transmissions, radiators steel off-cuts, nuts, bolts, screws, washers, etc. etc.
Seems I'm up & down those attic steps 10 or more times each day. Great exercise but not when one is feeling a bit dizzy with low blood pressure.
I have a similar setup in the roof of my house, the heaviest item up there is about 20Kg and the bulkiest are rear car seats, all squeezed in through a 800 mm square person hole.Nuts, bolts, screws, etc, I can understand. But my mind is boggling at seeing you carrying an air compressor and transmissions up a set of pull down attic stairs!!! You need one of those hoists hanging out through a window, like one sees in the old flour mills, warehouses, etc.
But my compliments to you, if it works!![]()
we had about 60 30l tubs of books "upstairs" in the old place, and a little block 'n tackle at the manhole to ease the man burden getting them up and down.could never imagine getting them up in the roof space or for that matter the roof trusses holding that much weight.
