Must have been faulty from new
That it!! I'm cutting out all my welds and starting again. . .
Question:
Has anyone ever had a go at trying to re-tape the steering wheel? Either with a new tape (if it is actually available anywhere) or reusing the existing one?
If yes, how was it done? Especially, what glue was used, how to ensure the start and finish won't come apart afterwards, etc.
Mine has got a few gaps at the top of the wheel, so you may have some tips how to close them up...
Cheers Sven
And another question while I am at it...
Has anyone had any success rejuvenating the original "Stoneguard" paint in the wheel arches or floors, etc..?
Sven
Thanks Bryce,
I might muck around a bit with the existing steering wheel band. How is it attached at the begining and end? Is it just glued on or else? Or stuck under the chrome cover?
Sven
My tape seems in fine condition, just has a few gaps... Do you think it is possible to unwind the old one and rewind it without gaps?
Progress has been good over the past two weekends. Have been putting Chris' welder to good use and have finished the complete roof rails, the boot panels and prepped everything ready for painting the whole boot / back end of the car.
Quite proud of my work actually... especially the dodgy repair on the left backend wheel arch has turned out really well. Remember what the price looked like I cut out?
someone bodged the holes with plate underneath, riveted them on and just added lots of under body schutz... not pretty at all. After a fair bit of rooting around with the hammer, vice and welder, the fashioned piece was in place.
My welds..? Still not pretty.... I think the gas ran out again, so "bird droppings" it had to be...
But after a few hours on the angle grinder (sorry neighbours about the noise! :nownow: ) it looked fantastic! The thing that took me three attempts was the plug welding of the seal retainer piece... beats me: I couldn't get the welds to penetrate properly. But after playing with the welder settings it finally worked! Once painted it'll be hard to spot where the repair section is.
Now I only need to put back the boot seal retainer (on the way / both sides) and it will be like new.
View attachment 74383 View attachment 74384
And Mark, you were right: After smothering the wheel arches' bitumen in truck wash and giving it a good blast with the steam cleaner... they came out like new! Nice and black. Didn't think that would be that easy to rejuvenate the stuff...
Before:
After...
The second job I wanted to finish were the roof rails. Done the right hand side last weekend. Again, cutting out the rusty sections, make up panel sections, weld them in, grind them off (hate grinding already... dirty, noisy, boring, worse than sanding filler...), degrease, metal prep, POR 15 x 2 - bingo: Nice and black and shiny. This weekend I did the left hand side - same deal with eight patches. Looks great! And sets the standard for the rest...
Also been umming and ahhing what to do with cracked bitumen drumming layer on the parcel shelf. Decided to just give it a bit of a clean and leave it in place. It gets covered anyway, but also retain the originality of the car. Will just paint the surrounds and that's that.
And then I had my first attempt at spraying 2K high build primer... :nownow: I have been considering to buy a compressor and spray gun for yonks... has always been one of those items I wanted, but always worked around it with spray cans, or mates or outsourcing.
Again, I thought I give those tiny PREVAL sprayers a go...
They fit about 175ml of paint and are supposed to be OK for smaller jobs... well, they don't work on high build primer! . The poor thing was spluttering and struggling to put any paint through that nozzle. I will have another play with them on the black top coat - might work Ok on "normal" paint, not high build..
Anyway, sort of got there in the end: Used up one spray can, plus a bit of "heathen" brush work - DOH! :disappr:
Voila - one primed backend. Ready for sanding and top coat.
But I think I am only delaying the inevitable... a compressor and gun is next on the list.
To finish off the day, I removed the steel crimping "snake" that is inside the rubber rail cover. As mentioned before, my rubber ain't rubbery any more - it is rock hard, so I had to use brute force and smash it to pieces... good fun!
Rewarding...
And one more: As the paint on my roof is pretty knackered anyway and needs repainting, I resorted to painting it myself. I still cannot decide whether the roof should be painted white (Blanc Cygne) or Silver (Gris Nacre).
So I painted half the roof white and half silver... using the sloppy method of a paint brush, matt ceiling white and silver metallic that I had left over (don't ask where in the house the silver has been used ).
Once the roof rails are 100% dry (i.e. next weekend) I will put it on and take photos from both sides to see what moves me most. To date the score is 4:0 from the neighbours/wife/kids in favour of silver. But not convinced yet, not convinced... .
Too common, or just pure 70s?
Silver roof... maybe not bad either...
Or complete make over: Bleu d'Orient with silver roof and a bit of "bling" (non Pallas that would be though!) Needs to remain a D Super after all...
It will come to me... one day... :wink2:
Til next week.
Sven
