Good one John, I see you have shortened the cable length by a couple of inches, hopefully the bracket can still reach the DPO or are you modifying the the mounting bracket as well?This type problem is common with many new marques of EU origin plus Ford Falcons & some Holden.
Problem is these components get so hot under the hood that these ball type connection's fittings become brittle & once removed for any type service, they're kaput. Refitted they just fall off when you don't want them to.
Auto & manual cables & rods are all the same.
There are some kits that repair some models, but this doesn't include the froggy ones & NEW cables are unobtainable.
Transmission Shifter Cable Bush Repair Kit - Under Console.
Easy to fit Automatic Transmission Shift cable end replacement bush to fit various models. COMPATIBLE DIMENSIONS: EYELET Inner Dimension: 10mm SHAFT Outer Dimension: 8mm Will fit various models with the same dimensions or same shifter bush housing including : CHRYSLER 300 (2005 – 2010) SEBRING...shop.powerwin.com.au
Used will be expensive & they are extremely difficult to remove especially in a U Pull It salvage yard unless fully elevated plus will be in similar deteriorated condition
So here's the $43 perfect permanent adjustable fix, new bellows & all ~ https://marinecontrolsystems.com.au/
View attachment 213158View attachment 213159View attachment 213160View attachment 213161
Google is your friend. I've finally worked out that a heim joint is a rose joint. Heim joints seem to be sold in Imperial units, and then of course I discovered it is an American company. We went metric more than 50 years ago of course.Released the bellows on the heim end & looks like no extension but plastic broken away giving quite a bit more length before threading to receive the female end.
If not long enough or different slightly less length it's EZ to alter by fitting a 6mm male type heim with 6mm joiner cut to appropriate length & locknuts used.
No mods needed just use what we have easily accessible.
Lot of work for a reasonably simple oil change!
That's why many really good ones are being scrapped!
Yep. Bloody krauts…I didn't like the "they fail often"! That's ridiculous. Is this the Siemens transmission?
