I've spent another 1.5hours sanding (gee's it's fun). Only one door to go now (remembering I'll do the new bootlid, bumpers, mirror, grill and bumpers seperatly later). Found a small crease in the bottom edge of the rear quater panel :doh: :doh: Next time I *must* get down on my hands 'n' knees and check the very bottoms of all the panels :nownow:
I painted the GS metalic, however could still see fine sanding scratches through the clear. I decided this was because when I use a flat colour and no clear, you can actually take out the really fine sanding marks with the top coat prior to cutting it. Though you can wet rub any orange peel out of the clear, the fine sanding scratches can still be seen in the base coat underneath. This time I will go over the whole car with some 800grit paper (I used 600grit to wet rub it). This way hopefully no fine sanding marks will be visible through the clear. 29.5hours now
seeya
seeya
