Mind - I know there are many variables in painting....and there are early cars where modern painting system has been used and they manage to look absolutely stunning...it's that relationship with the professional and getting the right job....
Lovely photo gents - well done!The gift that keeps on giving
After ‘event-less’ motoring for a few drives now; including a 250klm round trip on the motorway to catch up with Buttercup Bob and Tim in Baccus Marsh, the bugger mucked up today.
Under breaking the car made quite a bad shuddering and grinding noise… on and off, so I went home thinking maybe air in the system. Yep, a bit of air in the front, so bled the brakes and off I went again. After a short while the noises came back… hmmm, back home for a closer inspection.
Oooops… I found that the LH brake carrier pin somehow had worked itself loose and had fallen out, not only making the whole carrier move forward on braking, but also bending the calliper connection pipe to the point of a hairline fracture, letting in a tiny amount of air….
Bugger, that pin is gone! Not so! I luckily reinstalled the bottom cover plate only yesterday and the pin was lying in it - phew.
So, radiator and shroud off, pin reinstalled with a new split pin (where did that go? Did I never install it? Who knows…) and pipe removed.
Will chop the end off and braze a new fitting on it or find someone with the olive tooling…
Luckily no further damage - I guess those are the things that may still happen from time to time. I am glad the pipe end didn’t break properly and dump a whole lot of LHM on the road…
Brake carrier was about 20mm forward…
The offending pin…
Too squashed to recover…
All good fun. Sven
PS: A couple of photos from Bob’s round trim supplying sausages and Citroen parts and labour across Australia.
All three gents contributed parts and supplies to the Safari - thanks Andrew and Bob. View attachment 139911
And Tim!
Cccv has the olive tool SvenThe gift that keeps on giving
The offending pin…
All good fun. Sven
And Tim!
Huzzah! For a first time "fresh out of the box", that's pretty good.Safari special…
here a link of a short video one of the boys from the Bayside Car Group made of my Safari at the Beaumaris Car Show last Sunday - first time the car was displayed with another 200 cars and bikes… the car got a surprising amount of attention due to being different to the ‘usual’ American, British or German cars.
And even nicer to receive some recognition being voted third best car in the People’s Choice trophy!
Sven
@bleudanube Curious why the chrome paint rather than sending back out for anodizing? Is clear anodize the correct thing?I had another go at wrinkle paint with paint over the top - terrible, definitely not an option.
I found some Interpon powder coating wrinkle paint in Dune Colorbond - have ordered a sample and will have a chat to my powder coater to see what he thinks. On photos it looks quite decent.
I spent the last few days polishing the aluminium trim pieces for the roof. Straightening the trim, remove dents and sand out a fair bit of corrosion on some pieces - rewarding, but filthy work... some needed 10 steps! I had to go down to 40 grit on the rear lid cross trim, it was that badly pitted.
The three trim pieces at the top are the before: dented, dull, scratched. The below are sanded to 600 wet, then polished.View attachment 128934View attachment 128935
You can see the pitting on the right hand side - it was surprisingly deep, hence the 40 grit starting point.
The dash strip is causing me some headaches. It was badly scratched and dented as well, which meant I had to remove the anodising to fix it up. I am now contemplating whether to leave it polished, or try to find a paint that replicates the anodised finish as reanodising would likely damage the stripe pattern.View attachment 128937
The roof rack was painted with Chrome paint. Might dull it down a little with a clear coat to get closer to the original anodised finish.
View attachment 128938View attachment 128939View attachment 128940View attachment 128941
The rest of the days were spent cleaning rubber seals... the door seals are still usable, all glass seals need to be renewed.
Sven, curious what your dash is made of (if you know?). Mine is in pretty remarkable shape, but dirty. Am contemplating a cleaning and perhaps one of these newer UV protecting products. I think Ive seen recovered dash panels for sale as "leather", but also saw a questionable translation on Danchotron of vinyl. Neither would surprise. Any insight?
