hi Dano, if I recall the handbrake outer cable lower mount clamp is a variable to cable travel as it can be loosened and outer cable steel pipe can be moved forward or back to be another point of cable adjustment.so depending where clamp is positioned on outer tube will effect positioning of adjustments at cables..... ..jimMike,
Are your hand-brake cables really tight/taut. I've used new cables throughout and there is very limited cable movement. All cables are wound back as far as possible and the brake shoes have been adjusted to the slackest setting.
Just seems strange.
Any feedback would be appreciated.
Dan
Jim: It is a Jaeger on-off switch triggered at 0.4 bar or less, basically to tell you if you're running low on fuel or if the electric lift pump is not working right. Normal pressure is 1.1 to 1.4 bar.is that a fuel pressure switch on l/hand side of fuel filter housing mike? if so is it by light or gauge?.... jim
