very nice job Frans
it came out even better than I thought
jimmy
jimmy
Look what we have decided....I wonder what the meaning of restoration actually means? Does it mean to make it identical as new in 1968, or is it making it better than new or can you do what ever tickles your fancy?
With the engine and box in their current state, the extractor just didn't do it. This rusted piece was like a zit on a beauty queen's forehead.
It might look better now but does it add value?
Regards
Frans
Come on Frans, I thought you and I had an understanding
MODIFY EVERYTHING - including the lawn mower
You are a car owner, not a museum curator. Do whatever will give you the most enjoyment out of the vehicle. Chacun a son gout!
There is a demand for modified Djets as well as for original specification ones. I don't see you wanting to sell it for a good while though; they're too nice as a "C" road car - enjoy your 4 wheel drifts.
cheers! Peter
Hi All.
Tomorrow will be spent visiting panel shops for quotations and with a little luck the Matra will stay behind at a panel shop for it's new spray job. Very excited!!!
Hi All.
Frans;1274912 <snip> In the talk the driver complains about the gear selection said:Belatedly:
I find the shift on my Djet to be OK although it took some familiarisation. The gate is like an H distorted a bit so that the 1/2 & 3/4 planes are not quite parallel to the longitudinal axis of the car but twisted slightly. Dunno how or why. It's a nice shift once familiarised; one has to be definite & firm in movement &, of course, double-declutching smooths things as with all boxes.
Mind you, a past owner obviously didn't like things (& remember that my Djet had, at that stage, only done around 36,000 km from new, so wear would not be the issue). He rose-jointed every connection as the linkages go down the left side of the backbone, cross in front of the transaxle, go down the right side of the transaxle & connect to the input rod at the top of the rear of the boite.
I also think that the yellow Jet owner is a bit rough on the Estafette boite choice. Compared to what else was available to Bonnet from the Renault parts bin at the time, it was the best choice. Yes the 2 to 3 gap was over large (fixed for the Jet 6 which had some bespoke ratios but, in any event, not an irritation to me in my Djet V with standard ratios) but the boite was all synchromesh, robust &, because of its input shaft inside hollow output shaft design, managed to mount the engine lower than would otherwise have been the case - a good thing for the circuit racer it was designed to be.
That said, as 5-speed boites became available in rivals like the Alpine, the 4 speed of the Djet became a disadvantage. Matra no doubt had pockets deep enough to remediate things but by then they were looking past the Djet-Jet to their own M530 replacement for it.
cheers! Peter
