As mentioned previously the Matra has arrived here in NZ and most of the stuff have been unpacked. There are a few things missing and I will list it again as we progress through the resto.
For a start, the engine is in my stand and stripped. There were a few things that surprised me in the assembly by others. The head was very loose. I could undo the headbolts with a short spanner without much effort. The flywheel bolts could hardly be loosened with a long strong arm on the 1/2" square drive socket set etc.
When I took the head off I saw the pistons were of the "Alpine" type. I would like if someone can confirm this for me. I saw them on pictures from Mecaparts (I think). They have a huge dome and can be seen in the pics. They might even be forged pistons. it has a 78mm bore x 77mm stroke. That makes it a 1470cc.
I removed the sump and saw the crank was knife edged and lightened. The cam shaft is the very famous RA5 cam as used by almost everybody in ZA.
So all in all it is not a bad deal because all this can be used for another race engine and I can put together a good fresh, closer to stock motor for good driveability.
So if someone can identify the pistons for me, that would be great.
