Hi Manicgt
same as John w said,i haven,t seen those metal brackets before although they appear to have a part no,on them they may be a genuine competition accessory.As far as I can recollect the angle brackets that mount to rear crossmember down to your side mounts do have a raised vertical section in the centre of them to which the curve in your metal outer brace brackets would go over.It appears that the metal outer brace with curve in it would brdge across outer flange of rubber mount thus reducing flex in mount,almost giving a metal to metal join between gearbox and crossmember.As john said I used to use longer bolts on upper inner bracket mounts to draw bracket up to crossmember,fit outer bolts and then fit shorter bolts ot inner one at a time.this will bring the mounts up away from the boot (pinchpoint in your 3rd photo) which should be ok than.....just a thought...jim
