Mine is a 2016 build and the AC is very cold, even on 35degree days. Even with the seat coolers and the rear vents open.Question for owners of Koleos, circa 2018 build. I have a 2018 build 2WD drive petrol Koleos. Bought as a demo model - 5000k.
Air con has never got especially cold. Today in Melbourne it was 35 degrees. AC runs and cools a bit - but on lowest temp does not really chill the air.
My Laguna by comparison, even on very hot (40degree) days, gets so cold on the coldest setting that I have to turn the temperature up after running the AC for a while.
Anyone else with a Koleos of similar vintage experience this semi-cool AC?
Ian.
It's cold to the extent that you can't have the vents directing air onto your hands when holding the steering wheel because it's too uncomfortable.
If you haven't already done so, make sure the AC is set to recirc and measure the temperature of the air coming out the vents.
At 30 degrees C ambient air temperature, it should be blowing air in the low teens, give or take.
The air coming out the vents should feel cold, definitely something wrong if it's just cool.
Your Lag on the other hand, would be normal.
