Window switches.
Hello, I’m new here. I have a 2009 Koleos Diesel manual 4x4. Has anyone figured a way to make the Sun visors work properly?Broken tailgate mechanism and broken sun visor mechanism.
Unless your car was previously owned by a dwarf there should be nothing wrong with the sunvisors. The "mechanism" is exactly the same as every other car ever made, the vertical position and swivelling of the visor relying on simple friction to stay put. When owned by the vertically challenged and operated every five minutes to keep daylight out of their eyes the friction part of the "mechanism" can be overworked to the point it never recovers. The solution is to buy a second hand sunvisor complete from a vehicle previously owned by someone without ducks disease.Hello, I’m new here. I have a 2009 Koleos Diesel manual 4x4. Has anyone figured a way to make the Sun visors work properly?
Thanks.Unless your car was previously owned by a dwarf there should be nothing wrong with the sunvisors. The "mechanism" is exactly the same as every other car ever made, the vertical position and swivelling of the visor relying on simple friction to stay put. When owned by the vertically challenged and operated every five minutes to keep daylight out of their eyes the friction part of the "mechanism" can be overworked to the point it never recovers. The solution is to buy a second hand sunvisor complete from a vehicle previously owned by someone without ducks disease.
I'm 6'3" and rarely have to use the sunvisor except when riding off into the setting sun which I regularly avoid. My driver's sunvisor stays exactly in position even with a reasonably heavy bluetooth repeater hanging off it for most of it's now 14 year life. Velcro is artificial gravity and was invented so to be, I have not come across any other form in either spray cans or flat packed. Dave Cavanagh, an Aussiefrogs regular, might be able to sell you a tested and approved anti-gravity 2009 Koleos sunvisorThanks.
I’m the 2nd owner, the first is 5’8” and I’m 5’11”. The drivers side visor couldn’t rely on friction since before I bought this particular Renault in 2016. It started to fall to the lowest point (gravity overwhelming the said friction “mechanism”). The passenger side started failing a few years ago too. I’ve used an ugly but adaptable Velcro* solution after all other hacks failed so far.
Your Elegant solution of second hand visors that have plenty of magic friction has never occurred to me due to what I see as the worst execution of the friction design. Well, compared to every other car I’ve owned or driven.
Where would one try to acquire SAFE mechanisms?
*Velcro - conjure images of NASA use.
I like it, it’s an elegant way to hold the visor to the extremes. It wouldn’t give the incremental options.I’d be getting some adhesive and two magnets.
Could you elucidate as to the problem you are facing?Hi gang, can't find the info but I am sure someone has found what diagnostic tool works with Koleos series 1 (2010 car/diesel/auto). Can someone please point it to me?
Also, I know there is a procedure to read the code somehow, just don't know what it is. Any pointers, please?
That may be all it needs!No problem (maybe? hopefully?), just a check engine light on all the time. Just came back home, so no idea what happened (wife drove it). Otherwise, car all normal. Needs a service though.
