If you have a problem posting pdfs because of file size, they can usually be compressed. I use ps2pdf which comes with and uses open-source Ghostscript, but other applications can do it, including Acrobat.
Ray,Paul,
I think you have a similar problem to what I used to have on Mk1 R5s in ZA. The change over switch in the lever brakes. I used to glue a small detent micro switch in place and then then run the lights through a "flip-flop" relay mounted on the fire wall. I used to take good switches from scrap cars, but eventually ran out of scrap cars. It was a design fault at the time.
Ray
