Electrickery question.
Arto, when are we going to see your 5 door on the road?
Mrs has been asking the same question, in the meanwhile she had me replace couple of fence posts and couple of dozen fence palings, paint the house, organise old driveway to be ripped up and new aggregate concrete driveway laid (the concreters bobcat driver managed to drop couple of half pavers down the sewerage inspection hole, resulting in effluent back up), new laundry, wardrobe inserts, various Ikea products assembled, arrange and order new kitchen and new kitchen appliances, the kitchen n appliances are in my garage workspace waiting for the kitchen installation in June. etc etc, I know its excuses, but it's all I have, but you are right I'll have to stop the procrastination, right after I replace the termite riddled rear fence and fix part of the sleeper retaining wall. Good thing I am retired. ;) 🤣 🤣 🤣 :evil: :headbanger"
Use the 2pin or 3pin Non Load Sensitive tridon flasher, choice depends on how the dash turn indicator bulb(s) is wired.
The Triton website shows quite a few different flashers for different purposes. More reading to do..
What is the car?
The EP range is load sensitive, ADR requires post 1990 vehicles to blink fast when a bulb is blown.
If your dash has separate left and right indicator bulbs then use HD12, if a single bulb on dash then use HD13, these don't care how many bulbs in the circuit.
Mini’s have a voltage reducer for certain gauges on their binnacle for some reason - 12v down to a lower voltage that escapes me (But it’s not 6v). A friend on the Sunshine Coast used to make electronic versions. I could possibly put you in touch. He could maybe customise the voltage if needed.
KB
KB
Minis used a voltage stabilizer that kept the volts to the fuel gauge at a steady 10V. A lot of old cars used them (of a variety of voltages) to stop the gauge's readings fluctuating with systemic voltage changes resulting from the changes in charge and load.
good move on the white goods, you could have been waiting for months if you had left it any longer ,hope you arnt in a flood zone ,been raining here solid all day
I have all the bits, I have the know how and I have a few croissant crumbs to add the french content. I just have to find time to assemble it all, but I'll get there. :snail:
Chaps I am desirous of using one of these 6 volt Scintex flasher units so I can combine the rear indicators with the stop lights as in the lower diagram in a 12 volt car. I am unsure how the flasher will behave with the higher voltage and how I could slow it down if it flashes too quickly. They were used in 50s Renaults and Peugeots. American cars had a version as well.
Any ideas..?
View attachment 202257View attachment 202258
Hi Graham now just for the fun, after you get your new system working, how about this !
Take the Scintex unit above and connect a full set of wires to all the terminals and bind them in a harness long enough to go out of view nearby. :cool:
Then bolt the unit in a conspicuous place in the car. Everyone will want to know what is 'that thing there' :rolleyes:. You can supply various answers depending on your mood at the time and what you think of the questioner ??
Jaahn
Yeah I have priors on that. When I converted Genevieve to 12 volts I ripped the guts out of my old 6 volt Smiths regulator and dummy wired it into the harness with the real connecting wires secretly going elsewhere. No one has questioned it yet. :cool:
Schultzman, I'm trying to negate the need for stand alone rear indicators in a 12 volt car. The front will have added motorcycle flashers. Some old automobiles have brake lights that flash (yes red), it's a thing. But as in #5 I am working up a circuit using separate relays. Stand by for the solution.
Yes, I understand that.
What I am not clear about is whether you want to use single filament globes or double.
They will be twin filament globes but one will be used for the tail light/parker while the brake light filament will be shared with the indicator. All will be revealed in due course when I get the thing built.
To close off this thread I offer an update for whoever heads down the same path.
I ended up going with the circuitry shown by this guy below, it's really simple and actually works. I bought a 5 pack of relays on ebay for $18.50 and used a HD13 Triton flasher can. Otherwise I made a stylish Renault sheet metal box from scrap and other bits'n'bobs, nothing to it really. I also added a dash light function to my circuit.
