If the tool carries a Centring dot on the end of the bolt it would still be possible to use a thrust plate between the nut and spindle face. Just drill a corresponding depression in the centre of the plate.
Yes, Dennis he made a number of the various special tools . All probably totally 'over engineered' and beautifully made. I got on well with him and he also had a great turn of phrase.Would that person be Dennis Walton? I know that he made some seriously good stuff.
Thanks for the offer! I have the collets for the Spigot pin, but I lack the collets for the Ball pin. I will need to get some made at some stage. I have two acceptable shafts with really good stub axles (L&R) on them that Shane can use. That should get him out of trouble and maybe they could be rebuilt if necessary later on if he can find some crosses.
Shane, I can only see one cross for the cardan shaft joint. What are you going to do for usable outer crosses?I have the usable stub axle/taper here for the passenger front. I may not be able to dissemble fully the joint on the car, but I do have a lot of driveshaft parts here that are already dismantled that I can re-assemble the driveshaft from by not re-using the outer joint on the car (at least I think that works without pulling one apart so I understand how the joints need to be assembled/dissembled ).
Ridging of the journals and cup surfaces is most likely. Like CX trailing arms the needles rarely make a full rotation as they roll.View attachment 138603
Oh, if I empty the tins ... This however doesn't mean it isn't all junk! I guess I just clean and inspect the cross for out of roundness and pitting
another good reason to carry out a daily session of Citrobics............same in XM Xantia etc.Ridging of the journals and cup surfaces is most likely. Like CX trailing arms the needles rarely make a full rotation as they roll.
They will still never do a full circle. bearings like to roll. On the CX rear arms they move through a small arc of movement there entire service livesanother good reason to carry out a daily session of Citrobics............same in XM Xantia etc.
Same with needles in the cups of TA and D universal crosses.They will still never do a full circle. bearings like to roll. On the CX rear arms they move through a small arc of movement there entire service lives
A tri point (diamond) chisel to remove.OK, I'll need to add a ball joint key (if it exists for sale anywhere) to my shopping list I guess I better see if I can extract that key first, it maybe cold welded into place.
