Hi Guys,
the traction here has only one brake cylinder with a bleed nipple. The rest are bleeders with a bolt into the back of them. They don't allow you to hook a bleed tube to them.
Does anyone know where I can get M11 x 1.25 bleed nipples from? (what I have will work, but is a PITA ). The bolt screwed into the back of what must be the factory bleeders (I'm guessing it acts as a dust/dirt cap) is M6 x 0.9 ....... And its a real citroen bolt with the citroen chevrons on it .... bizarre. I've never seen a M6 x 0.9mm citroen fastener before.
I'm guessing everyone just takes this bolt out and lets the brake fluid spray everywhere? (I was going to try a vacuum bleeder on it ... but obviously cant without nipples ).
seeya
seeya
