Found it easier to drill all spot welds while it was atttached. The two hinge support sections that come apart will be easier this time.Really nice work!
The sill has the rust and will replace this like the last but only about 200mm. You can see the rubbish on the top of the sill after removing the a pillar.
Modify the section where wide wheels could easily touch! 25mm clearnce. And the front guards later.
Again after removing the A pillar, you can see the evidence of the third inner support steel has been cut to match it up to the hinge holes.
This steel inner support is mean't to be fixed in all the way up to the windscreen seam as extra strength. Useless.
