Very good carbie man in Osborne Park...…..
If that is the case Alan then no, 1 would be lower than No, 2 which is not the case. The idle screw is in the middle of both carbs. Hmm interesting
Perhaps over enthusiastic tightening of the shaft nuts? Too much effort to find a DCOE in storage to see if this works for your problem.If that is the case Alan then no, 1 would be lower than No, 2 which is not the case. The idle screw is in the middle of both carbs. Hmm interesting
The position of the butterflies can be checked through the little brass bungs that cover the progression holes, comparing the butterfly plates to see the amount of hole exposed to the main airflow.
I see your conundrum. You have the butterflies fully seating in both carbs with no idle screw in place, and yet at idle you have significantly more airflow on two cylinders using separate carbs.
I do think the additional progression holes can only help in the driveability stakes, although you have been far more scientific in you approach to this than I have been in the past. Nicely done.
I still like DCOEs, but nowadays I find the accuracy and adjustability of tuning fuel injection hard to beat.
Eek. I thought I was systematic, but you get the prize!
Thanks Alan. After talking with Ray, I may have setup the throttle plates incorrectly. So I will do it again this way.
- Remove the carbs
- wind out the idle screw on the lead
- undo the screws to loose so the butterflies are loose.
- in its closed position tap the shafts lighly between the screws
- This should vibrate enough to seat both butterflies
- check with a good source of light from the intake
- check for light and good seating
- if all good nip up the screws carefully keep it in a closed position
- tighten screws
- install carbs
- 1.5 turns on all idle mix
- 1/2 turn for idle screw
- start and warm
- balance both carbs (which cylinders is best????)
- adjust idle mix and rpm until good
- check airfow on all again
- BETTER???
- try air bleeds to balance all low cylinders
- BETTER??
- HOPE SO
Sounds like a good plan John, will be interested in the results.
This is the sort of trouble you get into when you mess with things by making careful measurements!! :roflmao:
Seriously, I wonder whether John's slight hesitancy will disappear? His car's that is....
