Late this afternoon, I shut machines down and had another bash at the DCOE 40's. Removed them and shined a light down all barrels. Very hard to see any light come through on both past the barrels. But I loosened the plates and tapped the shafts lightly to shake the plates to a tight fit whilst also holding the shaft shut. Nipped up the screws and then hard. Reinstalled, balanced and tuned. Now for air flow volume results:
I also took this opportunity to replace the accelerator pump spring to a harder one than standard and the spill valve back to a 40 to replace the 50. This was in the hope that I might rid of the slight stutter. Not quite unfortunately.
It drives nice though. But if you go to stomp on it can stumble. To be continued...
- No 1 and 3 has now 3.25 (down from 4)
- No 2 and 4 has now 2.5 (up from 2)
- No 2 and 4 added air with bypass to 3 (couldn't get any closer)
- Tweaked idle again
- Happy with that
