The plastic 306 AIT sensor from the 306 throttle body fits snugly in the same hole as the EVAP purge control line. Quick way to get up and running…
That'd be fantastic, thank you.Would you like me to email you a map? It will be for an XU10J4. You'll just have to change it to multipoint, etc. but all the setup and correction maps will be set.
Peter,Belzona is a much better product than Devcon or JB Weld.
I'd ring Rezitech and find out who your closest reseller is.Peter,
Belzona, where do you find it?
Also look at Splash Zone.Peter,
Coolant reservoir.I just had the same problem with my coolant level sender
is yours located in the reservoir ? or the top front right of the radiator ?
got lazy and just bought a new one from the Peugeot shop
but your fix is the better way
Well done! And thanks for thinking about IP. I’m obviously happy to share a map with anyone who asks nicely.
The trick to Quicktune, is keeping the load in the centre of a cell, so it’s not interpolating. Then hit Q. Hitting Q followed by W, will do cell above and to the right. It gets difficult to do 5000 rpm in 5th at 0kPa
Alrighty, next milestone complete.
Disclaimer: This is totally new to me. Peter has been feeding me pointers in the background for which I am very grateful, given I only get a chance to fire up the car once a fortnight or so.
So when I originally loaded in Peter's mi16 map it was far too rich at idle. He recommended I try a zero-throttle map to figure it out. The injection time was far too high to begin with so I managed to get it idling when hot with static times of ~3ms. Of course this meant I had to hold the accelerator ever so slightly to get it to warm up on the enrichment map. This is where I realised it was idling on the far right side of the map. With ECU manager, there is a moving cursor on the Y-axis and a cursor on the table itself. It was idling at 0kpa, which unbeknownst to me was totally wrong but I adjusted the VEs anyway to get a steady idle. I wondered why my VEs were so low in the 20s but I thought it was maybe a result of the cams.
It wasn't until I started loading up the engine trying to pull it out of the garage that I realised the pointer wasn't moving along the load x-axis at all. So I pulled up the load-kpa fuel gauge and clicked to me that it was a 1-1 relationship with MAP. And of course, being +57 kpa the pointer was actually off the chart but bound to the 0.0kpa column.
It turns out I calibrated my MAP sensor how megasquirt guys would, with 0kpa as full vacuum and 100kpa as atmospheric (absolute). Peter's map, following standard practice of Haltech load mapping whereby 0kpa is atmospheric and -100kpa is full vacuum. Makes sense given the legacy of using vacuum/boost gauges. This also affects how the ECU calculates its air mass.
I expected it to idle in the -50kpa range so I set all my values at the low 20s to begin with. It died straight away. I put in sensible VEs close to Peters map and it fired up straight away to a steady cold idle and happily set there up to temperature after some adjustments to get close to the target idle AFR. Forgive the blurred image, it would be rude to blatently share Peter's IP.
Reluctant to take it for a drive yet without a wingman and see how well Quicktune works. Looking at you Matthew
My latest problem is after putting in a new coolant reserviour I realised the sensor was never properly connected so it's now showing as low coolant. I pulled out the reed switch and found a pinhole in the silicone stuff they encased it in. Subsequently the conductor was broken and the reed switch doesn't actuate in the presence of any magnet. I'll see what I can get from Jaycar and make a new one.
View attachment 235582 View attachment 235583
Correct. Do you want me to have a look at the O2 table?Matt and I had a play yesterday in my driveway. Felt like some black magic trying to hold revs and hitting Q at the centre point with the cursor flickering about. After he went home I fired up the datalogger and realised I hadn't turned off O2 control, which was problably fighting us.
