Maybe your injector dead time is incorrect? As a quick fix, I’d adjust the injector size until you can get the idle VE number <50.
If you think it’s worth going back and using their new machine to graph the dead time properly I’ll do it.
Found another tutorial link more applicable to your ECU posted by some dude called Pitcrewyou can empirically work out a percentage correction to the PeterT deadtime table as per this
What part number are they?186cc/min vs my calculated 215cc/min.
If you can, upgrading now to 3 bar Mi16 fuel rail is well worth doing to get the best from engine mods.I would have run them at 3 Bar, using an Mi16 fuel rail and regulator. I'd never considered you'd be running at 2.5 Bar. Great effort getting that sorted.
Volume. I suspect it's bigger, hopefully @PeterT can confirm. The rail acts like a plenum, as pulsewidths increase (especially if 2 injectors fire at same time) if the rail volume is too small you can end up with standing waves that I've seen starve an injector of fuel.What's the point of an Mi16 rail.
The main thing is, it is very driveable! Already better than Jetronic.
I said that, as being past tense, in that the map I gave Lachlan was from an Mi16 using the 734 injectors.I would have run them at 3 Bar, using an Mi16 fuel rail and regulator.
