Thanks so much. In that case, I would suspect the transducer on the gearbox. Why? Because when the speedometer stops working, the trip meter, odometer and mpg check on the multi function display screen will stop working as well. Am not sure, but I think its also affecting the variable power steering when the car is stationary (not as light as it should be). My problem is going under the engine bay to get to the transducer. Just too lazy to craw under the car now. Anyway, will keep you guys updated.He means the odometer readings would be wrong. If the sender from the gearbox is faulty then both the speedometer and the odometer would not be functioning correctly.
