DJetronic ... Everyman as his dog seems to have done the conversion, so it shouldn't be impossible for me (famous last works). I'm pretty sure megasquirt could trigger with the ignition..... or even use the Djet points.Does the system in the ID use a mechanical points arrangement to fire the injectors? This was used as far back as the disastrous Bendix System used in the 1958 Chryslers. If you keep the distributor and coil ignition you can use Megasquirt 1, very simple and straightforward.
I won't say anymore here, I'm hijacking someone elses thread!
